Yamahaulin
- 695
- 12
- Jan 30, 2010
Bowling Green,
Kentucky
Ok all you E85 users, i have some questions. I have a single walbro 255 hp pump with -6an feed with stock return, 1000cc injectors. Will this support 500-600hp? I am thinking i might need bigger injectors and maybe i should replace the return to get rid of the 2 rubber lines out of the afpr and right at the tank. I figure the single walbro should do 500 but might need a second to hit the 600 mark. What kind of orings are you putting on your injectors and what about fuel basket?
