Ludachris
Founder & Zookeeper
- 8,060
- 3,085
- Nov 12, 2001
Newcastle,
California
Yesterday I drove to the store and came out and tried starting the car (my recently purchased 97 Talon TSi)... sounded like it was running on two cylinders for a few seconds and it died, then kept dying when I tried starting it like 20 times, still same odd running sound. When the tow truck arrived a half hour later it started just fine but threw a CEL. I drove it home with no problems. I checked the code with a scanner and it read P0340, cam position sensor. The car was still starting just fine today and idling fine. I couldn't see any issues with wiring.
I took it for a test drive up the street, all the sudden it dies completely and a big puff of smoke comes from the dash, I'm thinking ECU. I turned the key an no power at all. I had to roll the car back to the house. I pulled the ECU expecting to see a black or brown fried board and didn't see that. The only thing I could see were 2 or 3 capacitors that looked like they were bulging slightly, though I have no idea what a bad ECU would look like. No liquid mess or anything like that. I tried taking a photo but couldn't get it to focus close enough to see the capacitors. Are the bulging capacitors a big enough sign that the ECU is fried?
My questions are - is there anything I should look for before I plug in my new ECMlink ECU? I noticed some bare wire on the ECU harness near the plug, where there was likely a S-AFC at one point. I plan on fixing that. But anything else I should look at that might have caused the old ECU to fail? Would a bad cam position sensor fry the ECU? I'm afraid to put in my new ECMlink ECU and fry it too.
