ACWgraphics
- 47
- 0
- Jul 10, 2008
Farmington Hills,
Michigan
Ok Ive read so many different forums about this topic. Ive went from a Autozone belt, to a gatorback belt, to a Mitsu oem belt. Replaced the Harmonic balancer with a new oem (I do have a forged block bored .20 over) not sure if i should get a fluidampr to fix this?
Everything is aligned correctly, pulleys are clean...... New nylon bolts to hold the alt in place...
Its really a loud squeal with the oem belt, the best luck i have had was with the gatorback it was a very low pitched squeal and was consent.
Been dealing with this for over a year, and every shop i take it to, same thing...
