jayb903
- 99
- 4
- Jul 19, 2007
Fayetteville,
North_Carolina
Somebody please give me guidance.
I just finished doing 6-bolt swap awhile ago. Car shifted fine then.
Problem is I cannot get it to go into gear while running, but can when not running I can. I can grind it into reverse but I cannot even get it into anything thing else(1st,2d, etc).
Took trans down and everything looked fine and I bolted everything up. I still have same problem. I replaced M/c & S/c but to no avail. New TOB and flywheel setup. I adjusted the clutch and still nothing.
Shouldn't I be able to at the very least grind into the gears not only reverse?
I'm about to send to a shop b/c I don't really have time to mess with this anymore.
