dacowgod
Supporting Vendor
- 447
- 211
- Feb 3, 2006
Morgantown,
West_Virginia
I'm running the .55 BEP housing and see about 40lb/min at 22psi. At 28psi I'm seeing 47lb/min. Stock motor, stock head. Tuned it myself. Fix your boost leaks. I guarantee that is what causes those low lb/min numbers you are seeing.
Not to get off topic...but Boost leaks do not cause a Low lb/min .. In fact in almost all cases they cause an inflated lb/min.
The only exception to this is a Pre MAF boost leak running in blow through (which will cause NO change in recorded lb/min)
or a PRE turbo post maf Vacuum leak... which is really the ONLY case LB/Min would be lower than expected due to a leak but this is actually a Vacuum leak and vacuum leak only..
The only way a boost leak would cause a Low LB/min is if it were so large that it barely even make pressure...
Assuming the MAF is calibrated correctly ... His low lb/min is probably better explained by poorly adjusted camshafts, a restricted exhaust or some other sort of restriction .....
Anyways...I just wanted to clarify that...back to the Holset dicussions ;-)
