DeceptivePerfor
- 120
- 0
- May 6, 2010
Hendersonville,
Tennessee
My GST is a DD and a 2nd Project. I picked the car up cheap to use as a DD since 25mpg in mixed driving is better than my Mustangs 16mpg. I completely understood going into it that, I would have issues with the Eclipse as they are moody. Here is a few problems that I am just unsure where to start.
When the car is idling it sits about 700-800 RPMS, when I turn on the AC it drops to about 400 RPMS. If I come to a stop with the AC on and dont hold my foot on the gas pedal, at times it will stall. The RPMS drop entirely. I was thinking maybe the BISS screw seal or IAC as possible culprit. The RPMS just drop like a rock, it is fine with AC off.
Moonroof of course does not work. I push the button and nothing, not even a click like you get when the relay activates in a window. I checked every fuse I could find.
Keyless entry, I researched how to program the remote. The batteries in the remote are fine. It blinks when it is programmed but, the doors do not lock or unlock. I am leaning towards either the reciever or maybe my door lock relays.
Last, Turbo Timer. I have a Greddy Auto Timer. It will not stay programmed for the RPMs. I have the wiring kit so, it is not spliced. It is not hooked to the Ebrake or Speedometer wire yet but, it should still stay programmed to the RPM. I have it set to start at 3k. Sometimes it will start at 1k, 2k, etc. Could it be bad? Or maybe my ECU????? I bought it second hand.
