khartley
- 1,235
- 2
- Jul 20, 2004
Faith,
South_Dakota
I bought this 95 awd, put a tranny in it, went to start it and the clutch pedal fell to the floor. I bled the clutch and even though the pedal felt mushy, it worked. I tried to drive the car, and it feels exactly like it always has that 'slipping clutch' feeling. It goes in and out of gears like butter, but it creeps. If I mash the gas the rpms skyrocket, but the car just kinda creeps a little faster. I don't smell clutch at all (bad perm smell, right?)
I've bled the system out 4 times now. I adjusted the master cylinder rod so that the clutch pedal feels like it should, no more falling to the floor or feeling like mush.
I noticed that I can NOT push the slave cylinder rod in at all with my finger. The clutch fork stays in the middle, and with the clutch pressed it gets pushed as far over as it possibly can. But it seems like the fork never gets to be in its 'rested' position (closest to the drivers side) because the slave rod is holding it.
So what is my problem? I don't know any background on this car, I just bought it with a bad tranny and fixed that. What would happen if I shaved a bit off the slave cylinder rod? Or is that even my problem?
