volkerding95GSX
- 209
- 1
- Jan 23, 2010
Cape Girardeau,
Missouri
Can you help my friend and I settle an argument?? I say brakes will give you faster circuit times. I say, straight from my dsm book,
"let's say ## coming up on an end of a long straight, neck and neck with a car that is identical to yours, with one execption: it has better breaks, you have to hit the brakes 100 feet before the corner, but ## competitor can hit the brakes 80 feet b4 the corner and achieve an identical cornering speed. that meanshe has been accelerating for 20 more feet, one whole car length and then some. guess what? you just got passed, thanks to you lousy breaks."
my friend disagrees and his points are, "well both those cars stop at the EXACT same place. Friction actually stops the cars. Not the friction between the pads and the rotors, but the friction between the tire and the road. A locked tire is a locked tire. And while big brakes can lock a tire without having to push the pedal as hard, stock brakes can still lock the tires instantly if you nail the pedal. Therefore, stopping distance and rate of slowing down, is unchanged. the actual stopping increase will be due to a decrease in weight/sq inch of tire, which can be achieved by reducing the weight of the car (driver or car) and by increasing the "stickiness" of a tire"
Who's right, do brake upgrades stop you faster or not? do they make you faster around a track or not?
