4g63 Knock Problem [vid inside] please help.
bg300
66
Sep 7, 2007
IL, Europe
hello all
i got europe dsm :)
and i got some wird knock problems ..
My car is already several months without moving.
Because of some budget problems
In any case, the car was not going about close to half a year.
From time to time I move it.
But how long ago I did not move for about four months or so.
Then suddenly I started these problems.
Driving the car makes noises of VTEC:) ####ed up something like
the engine (I do not know how to say it in English properly) -
The car is not going well at all. Fidgeting, stammering, and turns
off at each stop.(And sometimes would not start again).
You can not go 40 mph the whole crazy Out with strange noises
and the trip was not smooth at all.
My friend checked plugs (We put new plugs) is not exchanged
Ignition Wires
It was a phenomenon with new plugs.
And just the video you will see that I started the car with the air
sensor, a second time. Without air sensor
Notice the horrible noises.
I have a program called AUTODATA I will try to inspect the vehicle
diagnostic errors that CHEAK ENGINE gives me .. And see what
they are errors
http://www.streetfire.net/video/4g63-knock-problem_2046757.htm
thanks all :thumb:
Just an FYI. Its not very smart to run your car without that sensor in. LOL
what is that ? FYI
why what happen when i run without a sensor ?
FYI= for your information
Sensors arnt not only used so you ( the owner) can see important information in your car, but the ecu also uses these values as inputs so it can make fine adjustments to run correctly. With out a sensor, the cpu only sees one wrong value so your engine isnt running correctly.
ok thnx for the info
:hmm:
