- Thread starter
- #26
dsmking101
- 224
- 2
- May 13, 2009
Utah
heres my orginal post i never said it happens all the time...only sometimes
im going to try this in the AM then let you know atruepretense thanks bro
hey guys i have a 1997 gst with original transmission all gears seem to be fine but 1st gear is a pain to get in i try to get it in feels like its in but as soon as i let off the clutch a lil it grinds hard ill try to put it in 2nd and put it in 1st kinda hard and some times itll work but most of the time it dosent itll just grind ....i need help with this bad all the other gears feel fine and grab fine its just first gear i caint even stop at a light with out running into this problem...please help thanks guys
Do this...Pump the clutch 4 or 5 times then try to put it in first, if it starts going in well like that, then it's your master cylinder or possibly slave. If not, then we will rethink it.
