Gasolinebaptism
- 953
- 0
- Feb 3, 2010
Kennewick,
Washington
The title pretty much says it.
I just installed a 2600, seems like I torqued everything down. for some reason my dad began to take the bellhousing away from the transaxle, but I got it put back together and torqued. There was a bit of residual oil in the area, but it never dripped. The transfer case does however seem to be leaking some. I'm not sure if it's engine oil or from the transfer case though. Engine oil is still full and fresh.I'd like to solve the problem ASAP. Is there anything common that happens, or what should I check?
