Marceldsm
- 321
- 2
- Jan 13, 2010
Montreal,
QC_Canada
so i repair all the wiring and the ecu
and men the car started like a beast
no problems what so ever only problem the TPS IS MISS AJUSTED and im getting a random tps code from time to time
THE TING IS THE CAR WORKS GOOD THEN.......AT AROUD 4000 RPM IT JUST CUTS
FEELS LIKE FUEL CUT
IS IT A VACCUM LEAK
A MAF PROBLEM ( I HAVE A NOTHER TO TRAY )
A FUEL PROBLEM ( MY FUEL TANK ITS ALMOST ON EMPTY) CAN THAT BE THE PROBLEM
I CHANGED
FUEL FILTER
SPARK PLUGS
OIL
COLANT
TRANNY OIL
IL ADD SOME GAS ( THE CAR WHASENT RUNNNING FOR THE LAST 2 MONTHS THATS WHAY THE GAS IS LOW )
THE AIR FUEL IS RICH WHEN THE ENGINE IS COLD( NORMAL )
THEN AT NORMAL TEMP AROUND 12,5 OR 13 TO 1
CAR IS COMPLETY STOCK
ONLY A 2.5 " EXHAUST WHIT NO CAT
FRONT MOUNT INTERCOOLER
update
i found a missive boost leak at the blow off valve
its fix new
same ting again , and the idlle swhich came off new the car revs to 1800 and stais there
will fix that sonn
shod a ckeck for leaks again or get a new ecu and see what happens !!!!
the ting is the car new revs to 5000 before whit the boost leak it revd to 4000
any ideas !!!
update
fond 4 massive bost leaks 1 at intercooler pipeing a noter at the blow off valve 1 in the vaccum lines and 1 in isc fix all
the car runs better
after all that i install a new ECU
Same story again
no codes do
the stange ting is if the tps is at 5% at idllé im not getting any codes and the car cant past 4500 rpms
if i let the tps at 2% ( i cant find 0) it gives me a tps code .........and the car boost to 5500 then cuts power
at 4000 rpms my data logger tells me 45 nock
84% injector duty cycle at 86% throttle
normal o2 reading
the car just cuts power right there
whay i need help please
i know its not the ECU
I WILL TRAY A NOTHER MAS AIR FLOW SEE WHAT WILL HAPEND
I CANT BE THAT 3 ECUS HAVE THE SAME EXACT PROBLEM
FEELS LIKE FUEL CUT
IS IT A VACCUM LEAK
I CHANGED
FUEL FILTER
SPARK PLUGS
OIL
COLANT
TRANNY OIL
update
its fix new
will fix that sonn
any ideas !!!
update
the car runs better
Same story again
no codes do
normal o2 reading
