SOLOR_ECLIPSE
- 0
- Jun 29, 2008
Tucson,
Arizona
I Just got the 99 GST back from the shop -
I had them install a new PTE SCM-5031E 50 Trim, 650CC FIC's, and a Walbro 255lph fuel pump..among a few other things. I have my profile up to date with all other supporting mods.
According to the shop, my PTE is only capable of producing 263whp on pump gas. At least that is all they were able to squeeze out of it on the Dyno. That in itself was very disappointing, but even worse, I finally build 19lbs of boost at 5000 rpm
then it drops to 14lbs till 7500. (No Boost Leaks or pre turbo exh leaks)
I am thinking the internal WG is opening too soon and causing this extreme lag.
Perhaps my AEM TruBoost EBC has a feature to keep the WG closed during spool up..that they did not compensate for..
This is my first 50 trim, which i was under the impression was to spool faster than this and be very efficient. My Big16G was producing more HP and boost with less supporting mods -
Any help would be appreciated!
