Parts
DeceptivePerfor
120
May 6, 2010
Hendersonville, Tennessee
Why is it so hard to find used parts or even just cars in this area? Does it seem to anyone else like this area is just a DSM Bermuda Triangle? Just seems like there is a lack of cars, parts, and Speed Shops in General for this area. It just seems as if this car is not really all that Tuner friendly for any type of car.
Any input, thoughts, etc?
Use craigslist.. i find parts usually. you just have to search hard LOL. Otherwise it seems you can type in anything dsm related into the search bar for atlanta craigslist and it brings up hundreds of results usually.
Here are some.
Wooo. Rough shell. @__@
I have one sitting in my carport. Sadly no title. xD I never went through the trouble of getting one because I just wanted it for parts.
So who's the friend in Dyers? I have a friend there also. I'm about 45 minutes from there.
DSMers are lacking around these parts.
My car isn't damaged in the rear.
See I told you it wasn't. Just has a primer spot on it.
i was taking the car apart and cleaning it up in the initial photo.
Oooo... I'd want the maroon one just for the color. ;P Mine is white. Just needs the engine as well, although I have a semi-built block. Front axles were trash so I tossed em. ECU is missing as well as the shift assembly. Annnnd it's on donuts. xDD
If you don't end up grabbing that one above, which there is little to no reason why you shouldn't. You can have mine dirt cheap. I've even considered just giving it away.
