silver bullit
- 2,314
- 8
- Jan 27, 2006
martinsburg,
West_Virginia
Yeah the chip for my 650 injectors 2g maf and other stuff decided to burn. Cheap ebay type china knock off with voids and air pockets in the hard coating. The car still runs and i am still having the same problem of it not revving past 4500-5500- or sometimes 6500. I have checked everything and it has to be ecu related as i put a stocker or any other ecu and it will run to 7500.
I have checked for the volts and ohm's between the circuits and all the voltage is checking out fine. the car still runs and boosts fine with the burned chip so i guess the board is fine.
These are questions i need answered.
What happens when you stick eprom chip in backwards? I need to know as the chip was soldered in backwards, from the repair shop.
Where i can buy a new chip? Cheap and fast only one i know of is http://simon.chi.il.us/ECU/ECURepair.html
What else or how else can i check the board with an ohm/volt meter? Or what tools do i need?
Any thoughts or advice would be helpful thanks.
