AL92
- 933
- 1
- Dec 12, 2003
regina,
SK_Canada
Been working on this for a few years now.
Car is 1991 awd turbo auto.
First thing did was to strip it down. This car is trailer only will never be on street.
Took out back bumper supports, front bumper support was replaced with lightweight jm fab one. Took off front and rear sway bars. Took out abs, cruise control, air conditioning, windshield wipers,most of interior but for now left front door panels, headliner,dash and center console.Taking out all insulation on floor and think taking off heat shields.
Running so far downpipe only. If some tracks require quieter exhaust have this insert that run in downpipe .It also lets me tune the car without neighbors screaming at me.
its made by car chemistry.
So far running steel hood, doors are not touched, steel hatch,stock glass. Do have some non power doors that can use.
Brakes have had 2g upgrade. Running powerslot rotors and kvr pads, stainless brake lines.
Battery is little odessy with jm fab mounting kit.
Suspension have kyb agx shocks looking to run eibach pro springs.
Wheels looking at some lightweight konig 16 by 7s.
Running megan downpipe for exhaust 3 inch no catback. No cat converter.
Fuel system consists of jm fab fuel tank,supra tt pump, FFWD fuel system with stainless lines, billet filter, sx reg, tweaked stock rail and 1150 FIC injectors.
Tuning is dsmlink, going to newest version and will run sd open loop. So no mass air flow sensor just map and iat sensors.
Electronics have aem boost controller and aem wideband. Autometer in car fuel pressure and egt. Have dsm scanmaster as well.
Got corbeau forza seat coming and have competition engineering 8 point rollbar waiting for install.
Still need to get belt. Got good helmet and fire jacket already.
Plan on putting in shift kit,end clutch kit, getting stock converter stalled up and going to welded center diff.GEt that stuff from idt? or whatever trans place is.
For turbo may run 13g for fun a few times this season. Then will run possibly 14b,
evo big 16, fp3065 or maybe fp red or something else FP . I may play with a few turbos or just go to big one right away. I could take one off my 97 talon its fp3065 and use something else on that car.
Would run likely external tial 44 or maybe internal gate if go to fp red.
Blow off likely tial blow off.
For engine thinking to swap in my 2.4 from my 97 and replace it with built 2.3 or would go with a built 2.0 maybe in the 91.
I have jm fab race intake with nitrous bungs if want to run nitrous later.
Will be using fp exhaust manifold, have mitsumoto rad and fans and shroud. Jm fab coolant overflow and ordering jm fab catch can.
Will be getting ets or maybe jm fab intercooler not sure if going to run alc injection on this car.
Going to manual steering and may go to cf hood, not sure about lighter hatch,doors, glass yet. Want to get 4 bolt rear end and possibly upgrade driveshaft and maybe axles see how that goes.
Goals are pretty modest ,would like to hit 10.xx something not into going 9s ever .too much hassle to do at nhra tracks but might try to make a 9 second pass on outlaw tracks.Will be track legal to 10.0.
Likely forgetting a few things. Will post some pics shortly.
The car is raceable pretty much today with the 13g .I took it to track near end of season last year but got rained out and didn't even get one run. I was expecting maybe a 14 with the 13g but was going to just do it for fun and to shake down the car.
I do also have my built to the hilt 97 talon dead in garage with either spun bearing or blown up clutch. It is my street car though not track car like the 91. It has never gone to track. And also have a wild super high hp 99 twin turbo trans am with direct port nitrous that is also my main street toy. The 97 and 99 will go to tracks but again will likely get best times on outlaw track. Neither of them has a rollbar in them at this time and may not put them in.
Anyway I like autos better for 1/4 mile cars. My 99 Twin turbo was just swapped to auto. My 97 think leave that one as 5 speed so have one stick in the stable.
Going to track last year ,got rained out, end of season so couldn't rerun it.
jmf fab bracket and odessy battery
engine before did much
