chuytalon
- 0
- May 12, 2010
mankato,
Minnesota
i have a 2g eagle talon awd going to drop a 6 bolt and wondering what is the best way to get 400h plus hp please help out
No, not for 400hp. Just 1 walbro 255 can make 450 on e85.
Very true. We made 525hp with one wally and a set of dechworks 1600. Compleatley stock 6 bolt.
Here is a link to the car I am talkin about. Brian is a good friend of mine. If you have any questions feel free to pm me or something.
DSM Forums - View Profile: GSXnoob
well you need fuel mods for that, no?
with stock 450s?
No shit. That's like saying you can make 400whp on the stock ECU with no tune at all.
I assumed we were talking about the engine itself here.
Well in that case:
- New Timing Belt and Components
- Eliminate the balance shafts
- Delta 272 Regrind cams
- A decent short-route FMIC setup
- Ported 2G or Evo III manifold
- Holset HX35 or BW S256 with a DSM bolt-on turbine housing
- 38mm external gate / o2 housing to support external gate
- Full turbo-back 3" exhaust
- ACT 2600 clutch or equavalent
- 255lph pump / adjustable pressure regulator
- 850cc injectors
- ECMLink / Ostrich or equivalent for tuning
Give it hell.
Are you joking, thats like fishing with a shotgun.
Bullseye Power or any one of their distributors whenever they're available. Lately it seems Bullseye has a habit of casting about 1/3rd as many housings as they can sell in order to create a shortage and (seemingly) drive prices up.justmx where do you get the turbine housing for the hx35 to bolt on to a dsm manifold?
Stock injectors from what? You could be using Evo VIII or IX injectors....those are "stock" too. With no mods to the ECU and an Evo III 16G, you should've been running out of fuel at 20psi of boost unless your base fuel pressure was 65psi.No offence to any fellow dsmrs. But I hit 11s with stock injectors.. and I thinkk 11s is like in the 400hp range ... this was my old set up , evo 16g ,safc2, fidanza flywheel, act street clutch, turbo xs b/c, k&n air filter, injen intake pipe,1g bov, alum pulleys,....but every now and then I got a lil fuel cut sputter! But like I said stock injectors...
Nevermind, that explains it.but I have a jdm enjine
