RiGs2G
- 165
- 1
- Mar 9, 2006
Lancaster,
California
Ill keep an eye on it thanks! I tried just a straight hose, but it would kink, so I like how well this 90 preformed hose fits. Maybe I can find something thats the same style but not heater hose, something stronger. ThanksBe careful using heater hose, it will eventually get spongy and break down from the oil I dought it was designed for oil to run through it
No I didnt port it at all. The flapper arm doesnt seem to move very smoothly and there is some slop in it, like the tolerances arent that great. Anyone else have this problem with thiers? This is without anything attached to it...Double check that the WGA holds a slight bit of pull, so you know the flapper is held sealed shut.
I went back out and re adjusted the flapper, tightened up the hose clamps, etc. I havent drove it yet but hopefully that helps
Did you port the wastegate opening at all? My 1G with the BEP bolton, external off the o2 housing creeps past 25psi.
Yes it is the stock Holset actuator. I know they are pretty heavy duty, but i thought Id still be able to run under 25psi. Ill take it for a test drive tomorrow and see how its running now with the adjustments I made. Thanks guys!Are you using the Holset actuator? If so, its probably got too much spring. IIRC, the lowest Holset actuator is on the WH1C at 17psi. Make sure its putting pressure on the flap when its suppose to be closed too.
Mike
