byebyev8
- 344
- 0
- Jun 17, 2004
kenosha,
Wisconsin
I know this is a old turbo but I picked one up in good condition. My goal is 500whp on the stock 6bolt under 30psi on e85. Its setup for an external wastegate but I'm getting my 7cm evo3 exhaust housing machined to fit the larger tdo6 wheel.
What exactly is the turbo? a tdo6 turbine wheel with a 60trim compressor wheel. Doesn't this basically make the turbo similar to a fp Red in terms of flow?
What should I expect in terms of spool up RPM? around 4k with 1g compression. I am running a working cyclone manifold so that help some.
