habitatguy187
- 3,635
- 253
- Aug 20, 2008
Indianapolis,
Indiana
Finally got some clean passes with the talon running "right" . Still on stock suspension with nothing done for traction except motor mounts. Tires are goodyear eagle all seasons, which aren't too bad but aren't very good either. First pass of the night was a 13.512 @ 110 with a 2.363 60'.
Second pass was the best of the night with a 13.489 @ 110 with a 2.427 60'. After this I turned the boost up and went slower, then turned it down and went slower yet. So the sweet spot seems to be 22psi, with half of it going past the rings and out through the crank-case breathers. So basically anything over 22psi and I'm overworking the turbo so much that it's just blowing hot air.
My 60's have a lot of room for improvement though. I was launching at 3 grand and slipping the clutch through about half of first then peddling 2nd. My buddies that were watching said my rear end was squatting like crazy, so I need to do something to stiffen it up for sure. In the end I was happy that I ran a 110mph trap but sad when I saw a rwd car run a 12.2 with a 111mph trap, then watched a evo run 11.9 @113.
Comments/Tips/Suggestions???
