Lofty
- 4,247
- 37
- Jul 27, 2008
Waukesha,
Wisconsin
I took off the driveshaft and didn't keep track of the order the washers went.
I have them labeled as pass rear, driver rear, driver front, pass front.
I didn't indicate the way the spacers went to the location of the bracket on the studs.
Example
bearing bracket
Bushing
washer
washer
Nut
That's the order I have it in for example on one stud.
Not too sure how it goes, is this neccesary or as long as i have the proper amount of washers will it be okay? Should I put a level on the driveshaft or something?
Thanks.
Example
bearing bracket
Bushing
washer
washer
Nut
Thanks.
