jm1080
- 640
- 3
- Jun 13, 2006
Boca,
Florida
Some holsets have the webbing without the porting all the way through to the compressor blades. Like my h1c. VERY quiet turbo, but has the webbing
The hit business has nothing to do with any thing. The bolton hx35 will pull harder than a 50-trim earlier given the same setup, bottem line. It spools faster and flows every bit as much through the turbine and more through the compressor at a higher efficiency.
First you were wondering if the hx35 "hits" like a 16g, then you're wondering if it hits like 50-trim or fp3052 . The 50-trim and fp3052 have different spool characteristics themselves and both are different from an evo3 16g.
I agree too. The 16g starts spooling slightly later than some turbos and comes onto full boost earlier vs. such turbo. Like even the 50-trim. or td06h 20g. Or fp green (VERY similar). This makes a sudden DIFFERENCE in torque, the classic 16g "hit". But the other turbos are building and making practically the same torque at the same rpm, given the same setup.
I get it now, and I never wondered if it hit like a 16g, 16g does not hit in my opinion, it does not pull me back or nothing, I said that because someone said it "hits" like their 16g, which is the reason why I'am questioning these holset turbos, I was like seriously?
So if it pulls you like a 50 trim or fp3052 or even more, than I will be happy because that is what I'am looking for.
