danielsl1999gsx
- 847
- 92
- Jun 5, 2009
los angles,
California
ok soo i had a problem with all the bolts in my pan having stripped threads causing me to leak massive amounts of oil. so i bought a new oil pan and gasket to fix the problem. But on the way to back from Autozone my Timing belt was all oiled up and i was leaking oil from my timing cover. I switched oil pans and new gasket but im still leaking from the timing cover and my belt is getting oiled up. I have removed everything, cam gear, belt, timing cover and cant find out where it is leaking from. Should i be looking for a broke gasket around there? or it could be the oil pan not tight enough.
