fastbike02
- 90
- 0
- Jan 6, 2010
dexter,
Missouri
OK I'm new to the 4g63 and have ran into some questions that someone more "seasoned" might know the answer to I'm about rebuild a 7 bolt.
the engine crankwalked and had a busted piston so it will be bored .030 over and line bored, and my goal is 300-350hp
1. My crank needs turned .010-.030, so should I have it turned or buy a reman one from Oreileys
2. If I have my crank cut, when I goto order bearings will the thrust bearing be oversized to, if not where do you get oversized thrust bearings
and last, of the two witch one would have a higher chance of crankwalk
