TRBOBLU
- 531
- 17
- Nov 15, 2005
Dayton,
Ohio
Im understanding that the gunk comes from essentially cleaning out the old lines and the fuel filter but luckily I replaced all lines and and the fuel filter. My car was already running on e85 with 750s for about a month.
Yeah im running e85 not gasoline. No I havent tried the deadtime that high just yet. I guess ill try that. I havent even tried wot of cruise just yet.
But I do also want to try the lower base pressure.
The gunk does not come from stuff in the lines and filter. This stuff is in the ethanol ITSELF and replacing every part of your fuel system will do nothing to stop it(unless the ethanol in your area doesnt contain the gunk). I have all new methanol approved SS lines, new fuel rail, new filter and still have this issue. Although the fuel here in Ohio does not seem to be as bad as other areas. But Im not trying to get people to stray away from E85. Its great stuff but you may have sticky injector issues if the car sits for a while. This is easily remedied by soaking the injectors in gasoline.
