abaum565
- 266
- 3
- Aug 9, 2006
Wausau,
Wisconsin
^^I seen that one. I know it can be done, the diesel guys have done it before. I would just like some info so I can be prepared when I talk to my machinist.
Remember that these recommendations are based on 15w40 mineral oil that is also recommended. This oil is extrememly thick when used in cold climates and drains very slow compared to even 10w40.
here is a good visual.You must be logged in to view this image or video.
In my semi, i noticed a huge difference in cold (below freezing) start cranking speed from going from 15w40 mineral to 5w40 synthetic. The 5w40 cranked over as if it was the middle of summer.
Does anyone here have some experience with automatic DSM's with bigger-than-stock turbos (on the stock converter & a 2.0)?
So to cut it bold and dry, will a -10AN be enough for the HX35? Some people are saying no and some are saying they are running with it fine. I already bought the damn thing.
I understand this, I just don't want people thinking that this drain is an end all solution to Holset oiling. It seems that the best results for longevity have been achieved by a custom drain setup with a fitting welded to a n/t pan and larger lines.
Just curious, how did you end up running your return on your Wh1c?
What i ended up with was something very similar to this.. The guy no longer sells the fitting, from what i see, that i got..
OBX OIL DRAIN FITTING GARRETT T3 T4 TURBO 5/8" HOSE : eBay Motors (item 160392973999 end time Jan-17-10 09:40:20 PST)
Then I went to NAPA and got 6in of 3/4(19mm) oil resistant tubing. I got a 2g stock oil drain and cut it about 2 inches from the coiled part. I applied some black gasket maker to both unions and used worm clamps.. It came out very well.. I ran no restrictor becuase I am all stock bottom end and on start up I see 75psi of oil.. So im above the required but when I first start driving I make sure not to boost.. So far so good... I DD this car..
i have a couple of question. im getting a hy35 for very cheap with only 55000 miles on it . from a 2001 dodge. has anyone used this turbo at all, and what are the results from it. and if someone has any picture or info on how i can mount my fmic with this turbo would be great it is a greddy with both pipe going to the passenger side of the car, and its auto. it is coming with the stock os housing i can use it right by just adding a pipe and getting it weld to my downpipe. please help im new with the turbo and set up. i only paid 100 for it. perfect sharp will post picture in a minute thanks
