toofast82
- 3,037
- 19
- Feb 8, 2005
Tinley Park,
Illinois
BEAUTIFUL RUNS! Just to throw it in there, I have the same issues with my PTE 5031RE as well (30psi dropping to about 25psi) AND I'm on a 38mm external gate off of the o2. I've since convinced myself it is due to the small turbine housing of the mitsu breed, since I haven't figured out any other reasoning behind it.
What spring/s do you have in the wastegate?
It's very possible its the housing, i've heard the bolt on pte housing is not the best.
Obviously the OP put down some pretty impressive numbers down with it though!
