forcefed86
- 1,007
- 12
- May 23, 2006
wichita,
Kansas
Installed new AFPR. If I set it at 42psi base, it will idle around 14.5 to 15.5. But WOT is 9.9. If I crank down base to around 32. I get low 11's WOT and 20's at idle.(idles is obviously ruff) Anyway to fine tune this a bit more? When I was running the OEM FPR I idled around 14-15 and wot was in the high 11's.
I am only running 14lbs or so. I suppose I could just set it back to 32 and up the boost to lean it out.
Thanks
Thanks
