RUBBERBURNER
- 60
- 0
- May 5, 2007
Hippolytushoef,
Europe
Hi,I have a EU 2Ga N/T with a electric problem.
It started when hooked up a alarm.I wanted to flash the turn signals when I arm it,but that didn't worked out well ... Ive wired it up on the hazzerd light and that burned my fuses.After replacing them my turn signal didn't worked,the headlight hight regulator stopped working as wel as the dashlight regulator ....
-I've bought a new dashlight regulator,but now it only turns the light on or off,I can't dim it anymore . Ideas ?
-I've bought a headlight hight regulator for in the dash,but they still won't work.The hight regulators in the headlight still work,i've tested them ... Ideas ?
-I've allso orderd a new turn signal relay thats mounted behind the radio.It was getting realy hot and smells like burned plastic,and 'ticked' very bad and even died ticking ... Think the new relay would solve the problem ?!
ps,this 3 things costed 450 dollar at the mitsu dealer here in Holland ....
