92tsifwd
- 572
- 0
- Feb 1, 2004
Hastings,
Nebraska
I was doing some measuring the other day and came up with apox 59 & 1/2" on the awd 1g dsm rear hub to hub. The fox 79-93 mustang rear end comes to 59 & 1/2" as well. I figgure after my 3 bolt goes I will swap in the 7.5" rear first then to the 8.8" rear. Both you can get 3.55 gears for with lsd. You would potentualy eliminate wheel hop & weak haftshafts! And there is alot more performance parts for the mustang rear setup like solid upper & lower control arms with spearical buschings, & ext. Also the ford rear is alot easier to get & cheaper. Plus the shocks & brakes are better off the mustang. This would be good for drag racing. For 2g's the 94-98 mustang rear is about 1.5"s wider. For those that auto x & need a irs, you could go with a 8.8 out of the lincoin mark 8 or cougers / t birds or cobras. A custom drive shaft would need to be made for this setup & it would require some fabricatring of a torque box.
