dsmusmc
- 422
- 1
- Oct 1, 2007
Alliance,
Ohio
jrohner is right, look at the bep .70 a/r housing. But in all practicality, the stock 12cm^2 t3 divided housing that comes with the hx35 gives you great flow. The stock hx35 hotside (housing and turbine wheel) has done 132mph with a full weight 1g . It's got enough flow to see the full potential of the 7blade hx35 compressor. And it's free. You will need to fab up your own o2 housing vs. buying what ever fits on the .70 a/r bep housing. But still that will be cheaper. AND the turbine housing is already there, free since you buy whole hx35s usually. . . Be sure to radius the divider or get hte PTE t3 divided gasket made for open headers to match up to divided t3 housings.
I actually got on here to PM you about this until I started reading this page. I just picked up a hx35 7 blade with the stock divided T3 housing yesterday. My question is will the outlet bolt to a typical T3/T4 5 bolt flange or do I need to find the stock outlet and fab one up from that? Im hoping its the same flange that I can get from forcedperformance or extremepsi so I can get it ordered today.
