RayBan GST
- 665
- 4
- Oct 21, 2007
DUBAI UAE,
Asia
hi all,
well i am now trying to help a friend so this i snot my car i am talking about:
here is whats happening , there is no sound of spooling and car feels like its not turbo its 96 eclipse gst JDM
we thought that the t25 is the problem so we installed another one ( still same problem)
we checked for boost leaks and made a BLT and found zero leaks
we changed spark plugs and filter and put NGK gapped at 0.28
we changed the BOV to greedy with recurculation tube ( NO LEAKS)
we have made so many BLT test with zero leaks
we have changed the injectors O RINGs
we have checked for exhaust manifold leak ( zero)
we have checked for exhuast filter if its clogged also ( it was clogged but we fixed it)
we have changed the MAF sensor
we have changed the spark tension wires
we have changed all the old pipes and made another boost leak test ( still no leaks and it can hold up to 14 psi)
all the gaskets on the turbo were changed NO LEAKS we changed the turbo in the end to 16G ( BRAND NEW) just got it a week ago with the J PIPE
we have redone the timing belt and the base timing to read 5 degrees now
but still nothing seems to solve the problem , please help us here we can not hear the turbo spooling and there is no power maximum PSI we can see on the aftermarket gauge is 6 psi( gauge is connected correctly) i have checked the arm of the wastegate and its good this is the third turbo guys and nothing is happening
before i forgot also we have changed the BISS screw with new one and new O ring
we have done a compression test and we got these numbers 172 172 170 160 across the line
what is left to check please let us know
