Silver 95 GST
- 160
- 0
- Aug 24, 2008
Daphne,
Alabama
Looks like a waste of time and money.
2 up^^^ What he said... and it looks like that turbo is gonna get shwacked in about 200 miles
My Ebay 16g is holding up fine i run around 19psi and it is fine about 3500 miles in on the turbo. I did have trouble with the waste gate canister not opening , but i just switched my old canister over. I hope yours works good for you. Nice looking setup.
all who think turbo will blow once he starts the engine up say I...
"I"
Everything but the turbo is fine. As far as that goes, the turbo is cheap because it is made the cheapest with the cheapest parts possible. I would use the manifold, and o2 but skip the turbo if you don't want to replace it any time soon. 16g's are pretty cheap, even used ones will probably have a longer life.
