90rslaser
- 266
- 1
- Apr 1, 2008
cheyenne,
Wyoming
alright guys so heres the deal. im out to try and set some records. around the colorado/wyoming area. maybe even the US if i get a lil crazy. i want to push the STOCK bottom end to its max power making potential limit, and have a fully built top end. the only problem im running into is head work. me and my shop got some ideas so far for the port and polish i want done, but that is a secret until its finished . but i was thinking of when were redoing the valve grind to only do a 3 angle. i have researched and i honestly think a 5 angle is a little too much for a boosted application. unless i was doing high compression and low boost. but as far as valves, seals, cams, guides, springs and retainers go, i need the EXPERIENCED peoples help. i need you guys to tell me about some of your experiences with head stuff and how well it worked and how long it lasted for you. personally, i am a brian crower cam guy, so im thinking im just going to stick with them for cams. great powerbands. let me have your insight and lets see what kind of builds youve done. also, if you have any pics of your top end after it getting built lets see it . thanks by the way, this is a 6 bolt motor. and im going to be running either a gt40r or a gt42r. i have both at my disposal just gotta bolt em up.
