tsi1991awd
- 1,366
- 6
- Sep 28, 2008
Puyallup,
Washington
I just had my clutch done, was at the shop when they reversed it out of the garage. Everything was good...shifts through all gears fine. I went to work, got off work and tried to put it into reverse to get out of my parking spot and it wouldn't go into reverse!
It doesn't grind, it's just completely gone all of a sudden. So I came home...next morning tried reversing to leave for work. Didn't go into reverse. So I pushed it out and went to work. When I got to work I parked and then tried to put it into reverse and it went in! I backed up and put it into first...pulled into a spot and then backed out. Went into reverse just fine.
Got off of work and it wouldn't reverse. Got home, wouldn't reverse. So today I changed the clutch line to a stainless braided line, bled it with a one man bleeder (there were no bubbles in it, I bled it for 15 minutes) I changed the shift cable bearings (skate bearing mod)....still wouldn't go into reverse. So I forced it into reverse and guess what?? It goes FORWARD.
What do I do?? I'm stumped!
