soldave
- 737
- 1
- Feb 17, 2008
Okinawa, Japan,
Asia
Got a friend with an Evo III who's encountering a strange problem. He's currently using an Eeprom chip (I believe from DSM Chips) which has been made for the Evo III. As part of the chip's code, a launch control feature has been implemented at 5,700rpm. The launch control works great... in fact it works too well and seems to be activated even when the car is moving!
Whatever gear he is in, whether at WOT or gently raising the revs (and even in neutral), as soon as 5.700rpm is hit he gets an ignition cut from the launch control. It's consistent at this RPM and he can't power through it so we are pretty sure it's not a misfire. If he does put his foot down he can build up boost but will not pass 5,700rpm. Also, encountering no knock at that level either. The speedo is working fine and reporting the correct speed, and the wiring from speedo to ECU has been replaced. Indeed, the entire gauge cluster has been replaced in an attempt to troubleshoot, but with no luck.
We're almost out of ideas, other than to remove the turbo timer, which we're going to do today. Wondered if anyone out there had any other ideas of things we could try.
Cheers in advance for any ideas you may have.
