DoyoFCT
- 224
- 1
- Mar 31, 2005
Dayton,
Ohio
Not to get off topic but I just finally got my .55 AR bep housing on my hx35 7blade. Question is has anyone else had a problem with the 2g o2 housing stopping the internal flapper from opening all the way? I just ordered an aftermarket ebay one with an atmospheric dump hoping that will solve the problem or am I going to just end up grinding that down anyways?
The problem is the Bullseye flange, is a mitsu "style" but it's not exact and with the 38mm flapper it can become an issue. You must use a bullseye flange style gasket because the mitsu style gaskets hang over into the wastegate passage area. I had talked to Punishment-racing, and JM fab about making an o2 that fit it exactly. Later on I decided to go with an ERL manifold with the wastegate on the manifold and a t3 .70 3inch vband outlet turbine housing rather than the .55
I believe theturbotrader sells a o2 housing flange that could be used to make an o2 housing and sell it both with or without the wastegate hole depending on your setup.
