chris712vt
- 524
- 6
- Mar 27, 2006
SLC,
Utah
Son of a bi***! I'm starting to hate this ####ing car, shit always breaks. Just when I'm arranging to buy MSnS, something has to go wrong...
A couple weeks ago I lost all boost while driving. Turned out my IC pipe blew off. Back when I first turbo'd the car I used what I had to piece together my IC pipes. Many short sections of 2.25" pipe and lots of couplers, worm clamps. Some places barely held together, it was a hack job and I knew I'd replace it eventually but as long as it worked I wasn't concerned with it.
Anyway like I said it failed, so I decided to get all new 2.5" aluminum pipes, good couplers, t-bolt clamps, yadda yadda and do it right. A couple days later, no boost again. ! But this time, no loud ass turbo hiss as it shoots boost right out of the compressor. Hmmm... (happened on the drive home form work just now)
Get home, check all the pipes and couplers, all perfect, tight, etc. Take my filter off the turbo, and I see grind marks all around the inside and the fins look slightly burnt up. Try to gently turn the wheel with the tip of a screw driver (way to hot to touch) and it won't budge. Seized. Pics speak for themselves...
I checked the oil and it's fine. My turbo oil feed comes from the same source as my oil pressure gauge and I've been reading plenty of oil pressure... I had hardly any shaft play before so it wasn't just bouncing around in there. I don't know what happened. Once it cools off I'll take the oil lines off to see if there's fresh oil on the inlet and outlet ports, or see if it's blocked up...
I assume the shaft snapped in half because the compressor wheel won't budge, but it drove fine (aside from no boost) on the way home (wastegate closed) so the turbine wheel had to have been spinning... I assume. I haven't taken the downpipe off though, too hot right now.
####! Some days I just want to sell this damn car...
