olmytsi
- 3,079
- 18
- Jan 29, 2004
Miami,
Florida
What kind of airflow are you guys seeing at 21 psi on big 16g's? Stock cams and intake manifolds.
Your friend is entirely correct. I would argue that most 16g equipped DSMs do not make 300whp+. I would also argue that this thread is no indication of, well...anything. For obvious reasons.
There is no question that 16g's are capable of 380 and apparently even 499whp. But, the thing is, the number of people cracking 300's is minuscule and are definitely the minority. I would argue that most 16g owners hardly even visit dsmtuners, if at all.
Those less dedicated or less informed probably don't the have the perfect fuel setup, nor the tuning knowledge to make it happen. DSMtuners is something we take for granted.
Unless there has been some drastic change, 2 years ago there was proof that few break 300whp (despite the many who do) in the form of the dyno slips and other available resources that could indicate "the going rate".
The bottom line is that the knowledgeable DSMers break 300 and the less knowledgeable don't.
I say this will be based on the fuel being used in most cases.
The race gas, e85, meth injection guys are probably all capable and likely to be making over 300whp.
The straight crappy 91-94 octane guys are probably making sub 300whp on the average setup.
Then you have a lot of guys who just claim numbers or exaggerate to over inflate the 16gs image.
Man I need to get my car dynoed. Im guessing 400+whp from the boost levels I'm running and cars I have said goodbye too. 16g hits 30+psi (guessing 32-34psi) and falls to about 26psi by redline. Timing is conservative when the turbo spikes and is at about 22* by redline. Im running a safe 11.5 afr on e85 and I get 2-5 counts knock at most on a hot day. When I get some better tuning I will be adding a 75 wet shot of some nitrous and hope I can see near 500whp.
I'm In 451 Whp On Evo 3 16g All Supporting Mods 93 Octane On Mustang Dyno Fwd
414HP, 459torque yesterday on a dynojet. E85, boost spike (crappy mbc) 27-28 psi or so that then settled in at around 22psi. I absolutely can't get more psi after putting in the cams, although it has way more power with less boost.
I like those numbers.... Hows your 750s keeping up, internal gate or external, and what type of AFR compression and timing was you on if you dont mind sharing?
