bastarddsm
20+ Year Contributor
- 5,643
- 1,476
- Aug 26, 2003
Mendota,
Illinois
So my car has got a n/t shortblock with a head thats been cut like .050", works out to have like 9.5:1 compression...kinda knock happy sometimes. so E85 was in order. Our cars run extremely rich at wot from the factory, this puts us in the ball - park of what E85 wants. all thats needed to get the rest is elevated BFP. This works well on a 1G because the BFP is very low.(36psi). So by bringing it up to about 55psi we trick the ecu into adding enough additional fuel run E85. Because of the high pressures a 255hp should be used.
Back onto my car, I modded a n/t fpr to be adjustable. With straight E85 and the new regulator, the car runs amazing now, on the logs I get no knock, about .83v on the nb, and 22* timing.
Running 9psi the car would trap 90mph, just changing to E85 the car now traps 101mph..Not a bad improvment for a butchered fpr and cheaper gas...
