CheaCheaBoy
- 139
- 1
- Nov 25, 2004
Boston,
Massachusetts
I want to install new cams for my car.
It's currently a stock 7 bolt with a 20g turbo.
I thought about doing a 6 bolt swap, but money is a problem
for a struggling college student. Also I just my car to be reliable with a little umpph.
Also was wondering whats cheaper, buying a built motor or making your own?
So I am looking at the HKS and the Brian Crower Cams.
I don't know what the setup should be for intake and exhaust, 264 +266, 264 +272, 272 + 272, etc. I need your assistance for the setup because you probably have the setup and can comment on it.
Also, I took the valve cover off to do a personal paint job. Are the camshafts plug and play ? Also is it recommended to upgrade the cams also. I don't want to upgrade if it could possibly ruin the motor, with bad timing.
My goal for my car is running low 13s.
Thank You
Thank You
