Daveed
- 231
- 0
- Feb 25, 2005
Olympia,
Washington
Is there anything that might hang me up or cause frustration by bolting it on before I install the motor?
So far on my long block I've got the timing belt tension set, the water pump on, the oil pump on, the intake and exhaust manifolds, the clutch, the thermostat housing.
Should I put on...
turbo?
the valve cover?
the big bottom half of the plastic timing cover?
The cam gear cover?
Alternator?
t-case?(is this in the way of bellhousing bolts?)
PS Its a 1990 TSI AWD
Should I put on...
turbo?
the valve cover?
The cam gear cover?
Alternator?
