Plaser
- 228
- 0
- Jan 13, 2008
moses lake,
Washington
ok so 1st is sometimes hard to get in and will sometimes grind a little.. now 2nd will go in if im easy but it doesn't just slip in, it takes a lil effort.. but when im high up in the rpms and i try to slam it into 2nd it just stops and wont go in.. ? i tried the linkage adjustment at the shifter off VFAQ but they were already adjusted.. it used to do this but it is much worse ever since i got a new clutch put in at a shop.. what could the problem be?
