-LA-
- 95
- 0
- Dec 26, 2007
Owensboro,
Kentucky
Your switch might be bad. The switch works off a ground. So you could pull the switch out,(leave wires hooked up to it), and use a test light, hook one end of the test light to ground(-), then touch one of the three prongs and see if the roof opens are slides back, going through all 3 prongs to find which one moves it back.
When you hold the switch down, can you here the motor trying to move, or the motor itself pull down, when trying to get it to slide back-wards?
