- Thread starter
- #26
Spyder4g64
- 356
- 2
- Mar 9, 2005
Wallingford,
Connecticut
You can use a Sandwich plate but depending on the turbo you use and the size of your downpipe you can run into clearence issues with the Oil filter because of the extra length of the filteer housing. Most people will just go out and buy a new or used 90 oil filter housing and use the stock oil cooler line location. All in all, I suggest the 90 oil cooler method.
I personally have to do this because there is insufficient room for my V-Band Downpipe from my GT35R. Im still actually going to be using either a Subaru Oil filter or a Miata oil filter.
I think once again it depends on what oil filter , depending on the sammich you use it could come in contact with the bottom rad support \ support beam. Most people running the forward facing oil filter have a gigantic down pipe and use it mostly for strip , so a oil cooler isnt of much use .
Yeah, I just connected them together.For those who used sandwich filters, how did you stop the coolant lines? Did you just pull them out from the oil filter housing and just connect it together?
Use aluminium AN wrenchesSpyder4g64 said:Any tips for NOT scratching fittings?
Can some of you guys that said you would get pics maybe put some up? I know this is kinda old, but I'm really considering re-doing my whole oil filter setup and running a forward facing filter housing, sandwich adapter, and a cooler. I would really appreciate pics since I can't find any.
Just another quick question...
Any tips for NOT scratching fittings? Right now im just using a rag, with an adjustable wrench.. haha.
