assault187
- 567
- 5
- May 16, 2005
Horsham,
Pennsylvania
Picked mine up for $300 running condition picked up.
C-mon... If you buy pistons there like $400. Rods are $600 for Crowers even....
Get a crank....Cheap..... MAchine work..... 300 maybe. Assemble your self...Free!!!
I got $1300....With my addition...
$3k for a buschur stg 3 block maybe..
Your forgetting about bearings, gaskets, belts, oil pump, water pump blah blah... I'm not just swaping out a block, if I build one from the ground up its going to have new everything and thats not even getting into the head. Are you going to leave your stock headgasket on?? Stock head studs?? In my case timing belt??C-mon... If you buy pistons there like $400. Rods are $600 for Crowers even....
