missionx96x
- 136
- 2
- Jan 30, 2006
Jackson,
New_Jersey
im having install problems. I alrdy cut the frame where the uicp needs to go through. but now it says to use the bolts from the fog lights to bolt it to the car. problem is i dont think theyre long enough or storng enough. i cant find a longer bolt with the same thread? what should o dio? i cant use a nut and a bolt because theres no way to get the nut inside because theres sucha big lip where those electrical wires go. i have no idea what todo now. use one of those sheet metal screws to self tap it to the frame?
