g00s3y
- 168
- 1
- Apr 29, 2005
East Brunswick,
New_Jersey
Well I just recently replaced my: pressure plate, disc, flywheel, slave cylinder, master cylinder, new ss clutch line, throw out bearing, clutch fork, pivot ball, flywheel bolts. The car was driving fine for about 500 miles. Then just yesterday my car would not want to shift, or would need a ton of force, to get into gear as i am driving. If i just turn the car on and shift it's completely random what gears i can go into. I press the clutch and can't go into 1st or 2nd, but can go into 3rd, 4th, & 5th. I let go of the clutch and try again and i can go into 1st and 5th, but not 2nd 3rd or 4th. I go again and same things, different gears go in and different ones won't go in. Weather i am sitting or driving, it will shift out of gear fine, but 85% of the time it won't shift into gear. I'm thinking the rest of the transmission is done, help please
