kmoore
- 1,241
- 13
- Mar 8, 2006
St, Louis,
Missouri
Not a problem. It helped me out a lot too.
Yea, it looks like it fills the opening perfectly. Except when you look at the pictures the endtank shows more on one side than the other. I'm not sure if thats a R&D error or an install error.
Yeah, that is the only disappointing part about the kit. He said that that was the only cutting involved to fit the FMIC. Other than that it looks like a solid FMIC.
So basically its a design flaw that the intercooler doesn't sit centered?
Kyle,
Thanks for all your help, I'm slowly putting this together. I'm assuming when he said bumper cover he meant the actual bumper you see on the car and when he said bumper he meant the black long fiberglass piece on the inside of the bumper?
Exactly. That is exactly how I took it.
Damn that thing is HUGE! Thanks for the pics. And about the power steering lines, Exile said he just removed the metal tubing and just looped the to hoses together right by the actual power steering resevoir. BTW did you polish that FMIC or did Dejon do it?
Mine was fine, i also put spacers behind the top brackets though so that might be why mine doesnt touch it, and as for the PS lines i just took a rubber hose and looped it right back in eliminating all the hard lines in front.Jeff,
Thanks for the pictures, I took a look at your write up. How did you install the FMIC with this piece still in? I found it to be impossible? Unless you modified it.
In your photo it is not clear enough for me to see how you made it fit. BTW, I ended up removing the power steering lines all together, they were getting in the way off the piping. I tried to mouth them behind the support bar as in the picture but no go.
Man I was really set on this kit once I found it as well. I'm running their intake and upper IC piping fine without any problems, but after doing a 6-bolt swap with the 1G IM, the IC piping sits higher resulting in the fuse box being raised. Also the 2nd to last bend going to the TB had to be dented a bit to fit over the thermostat housing.
Soo I'm going to have to make a custom FMIC kit and do short route piping.
Thanks for the heads-up, Im in the process of a 6bolt swap right now. Ill keep that in mind. Its too late now, I already purchased it.
Yeah no problem. I actually had to revert back to my 1g BOV too, I had drilled holes in the existing flange to run a Type-S that wasn't being used but now I can't use it.
Also on the same note, they sell an adapter that would make the Type-S or any knock-off of it to bolt-up to a 1g flange. The piece fits nicely but you won't be able to close your hood (oem) if you installed the adapter. It's funny how they advertise it with the exact piping I have from them, yet they forgot one thing. I'll just hold on to the adapter for when I get short route piping so I don't waste the $25 I spent on it.
From the pics I've seen on this thread I have a couple of things to say.
1) The short route intercooler has terrible end tanks. Any time there are sharp edges in the path of flowing water (or air in this case) it will cause dissruptions in the air. I do not recommend this type just to get a shorter route to the throttle body. It cancels out what you gained from the short route by disturbing the air flow.
2)For the price the side to side IC that was pictured last was ok. The endtanks are still small but at least they wont hurt the air flow. Larger end tanks will flow better and will have less pressure drop. I would not expect to make a ton of power on this type of intercooler but it should be fine for a moderatly powerful street car.
