danyz250f
- 631
- 6
- Mar 13, 2005
Rexburg,
Idaho
118 mph in the 1/8 mile is movinggggg. I'd be happy with the 118 in the 1/4 hahaa
Fo sho
Fo sho
Happen to get any videos while at the track?
Good luck next weekend, looking forward to the results
your car is one very well put together dsm..glad to see its running good even though the transfer case didnt like the launch..i feel like my t67 is nothing compared to yours
Can't wait for more passes Jake! Looks like you redlit on that second pass anyways though. Hopefully you'll be able to make a full pass this weekend for us all to see!
The redlight doesn't matter, it was test-N-tune day anyway, no racing going on. R/T has nothing to do with the ET or MPH if you sleep at the light or red light. It's all the same.
Props on getting everything running smoothly man! How much of an improvement does the nitrous make on spoolup, and have you thought about spraying it all the way through?
I'm absolutely shocked that your Tcase lasted that long anyways! Have you looked at the DSS Tcases? Also I wanted to ask what suspension and cams you went with, and if you were still running stock axles?
Edit-And I don't think anyone wanted to watch a vid of you breaking stuff as a bad thing. DSM'ers rally behind you, and we ALL get excited when we get a chance to see what you're up to!
Thanks for the props man, I do plan on runing the nitrous all the way through, I only have a 1/8mile pass on it this season so far, so I am working my way up with it. Once I feal the car is dialed in then I will run the nitrous all the way through.
The DSS t-cases is alittle out of my price range for now, the funds for the talon has ran low for the next couple of months.
I don't really have anything fancy as far as suspension goes, it's just GC coil overs with KYB AGX's. As far as cams, I am still on the HKS 272/272 cams, the cams are not doing me any good at this point as it needs more. And yes I am still on stock axles..
The DSS t-cases is alittle out of my price range for now, the funds for the talon has ran low for the next couple of months.:
Oem green axles right? The remanufactured axles that you buy at parts stores are not nearly as strong.
Congrats on the new and improved mph Hope to see some 8s from you this year
Yes the are OEM greens. I have never changed them as of yet (knock on wood )
My new turbo is bigger, 5in inlet YO MUHAHA
check it
http://i137.photobucket.com/albums/q218/lelej1080/turboquortor.jpg
http://i137.photobucket.com/albums/q218/lelej1080/turboquortorzoomout.jpg
http://i137.photobucket.com/albums/q218/lelej1080/turbomesur5in-1.jpg
GOOD job on the build keep us posted!
